AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Mapexport programmatically does not export Object Data.
0 REPLIES 0
Message 1 of 1
425 Views, 0 Replies
I need to export a large amount of dwgs to SDF, with Map 2009. I need to includein the SDF's some object Data.
In order to do so, I create a profile pointing out which Object Data i need to export along with the SDF.
If I doit manually through the "mapexport" command, loading the profile, everythink works fine, the Object Data are export as well. When I see the data through the Maestro 4.0, i can see in the layer, together with the object data exported.
BUT (but but but), if I do it programmatically with:
(command "-mapexport" "FDO_SDF" sdfFile "Y" profileFile "P" "")
I export the SDF file, BUT (BUT!), it is not exporting the Object Data! (it doesn't appear in Maestro 4.0)
Resuming:
In both cases, I use the same profile. Manually, it export the Object Data, programmatically not.
Any ideas why?
Or, there is another way to export or convert DWG's to SDF?
thanks in advance
0 REPLIES 0
”Boost
