AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
mapbook titleblocks.
2 REPLIES 2
projects45
356 Views, 2 Replies
I’m new to map books, I have gone through several tutorials, having trouble modifying the title blocks for the mapbook templates is there a specific folder that I need to save the adjusted title block in. Going through the block editor doesn’t work so I’m exploding the block and once I do that the links have been broken between the title block and map books. Have a good day.
2 REPLIES 2
Murph_Map
in reply to: projects45
Have you seen this? http://map3d.wordpress.com/2007/08/12/map-book-part-2-the-template-file/
Murph
Supporting the troops daily.
projects45
Sorry for the late reply, yes it is helping I have made a new TB and put it in paper space and have given the layout a name but when I insert it in a mapbook it does not show the layout name in the layout name dialogue box, that part of the link is not there, the tb file is save in the template file with all other templates for autocad. Have a good day.
”Boost
