AutoCAD Map 3D General Discussion
0 Kudos
Post 1 of 5
Map3D Surface Importing
521 Views, 4 Replies
06-06-2011 03:04 PM
Hi all,
So this is a follow up to a question I have previously posted.  I have updated my machine to a 6 GB Windows 7 machine, but still am having the same issue with the surface importing.  I am able to generate the surface; however, when I attempt to "Add to Map," Map 3D 2012 crashes.  It took my 48 hours and almost 100 GB to manage this LiDAR data, but to not be able to import it seems to put me in a helpless situation.  Any recommendations as to more efficiently import that surface, or is 6 GB futile to the mass that is a 3D surface?
Best Regards,
Kevin
196 Kudos
Post 2 of 5
Re: Map3D Surface Importing
06-07-2011 12:43 AM in reply to: kt_akel
Try to simplify your point cloud: I use the opensoruce Meshlab to do this...
0 Kudos
Post 3 of 5
06-11-2011 09:27 AM in reply to: antoniovinci
After you expedite the point cloud, what do you see as the best way to generate the surface, and more importantly, add the surface to the map.  My surface was over 80 GB.  Is this normal?
196 Kudos
Post 4 of 5
06-11-2011 09:45 AM in reply to: kt_akel
I am testing the trial version of Map2012 since only a week, so I may tell you that:
1] from a point cloud, Map2012 generates just contours, which you can save as .SDF file
2] you must have Civil3D to make a TIN surface from that .SDF
I'm used to manage point clouds in Meshlab (tool made in Italy, I say proudly..), where I also generate the mesh, then I export it in .U3D format to Acrobat 8.1 Pro, which makes beautiful PDF_3D - see the attached interactive file.
0 Kudos
Post 5 of 5
06-11-2011 09:51 AM in reply to: antoniovinci
wow pdf maker does do an excellent job.  and map2010 can make contours as well, once the surface is generated and imported as either a geotiff or and ESRI asc file.  once you import either of those files as a raster, you simply right click and click on generate contours.  where I run into the snag is the importing of the raster.  the image file is so big that it seems either CAD or my computer cannot handle it.
