AutoCAD Map 3D General Discussion
Distinguished Mentor
thepworth
Message 1 of 2 (330 Views)
Accepted Solution
Map3D - MS Excel 64bit
330 Views, 1 Replies
03-13-2012 01:28 PM
O.K. so today I'm having yet another "brain fart"
I have a map with a .SDF attached.  I took the .SDF and copied/pasted into an Excel spreadsheet.  This was to do a mail-merge to request access to property to collect samples from multiple folks.  As I'm getting the responses in, I'd like my admin to update the responses & contact information we get back.  Seems logical as my admin knows Adobe Publishing, & barely knows the MS  Office suite.  Rather than confuse someone with my ineptitude with database forms, I thought a spreadsheet would be the way to go.  linking to Excel isn't my first choice, but...
I put the attached document together in 2010.  I can get as far as configuring & connecting to the data source, but then I get a red "X" through the connection on Map Explorer even though it tests successfully.  I went so far as to uninstall 32-bit MS office & download/install 64-bit (yup, the machine came pre-loaded with 32-bit - MS help actually took my call and had a link to a 64-bit download path to me within 8-minutes, so I was feeling pretty good until a few moments ago).
Other than moving into MySQL, any thoughts as to why I can't connect or suggestions for what else I might try?
TIA!
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
AutoCAD Map 3D needs to know where in the workbook to look for the data -- so creating a named range (or in newer versions of Excel "Define Name") is required. Taking this step resolved the issue.
Product Support
phil_borycens
Message 2 of 2 (248 Views)
Re: Map3D - MS Excel 64bit
04-10-2012 02:11 PM in reply to: thepworth
Phil Borycens
Need installation help?
