AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map3D 2010 Fatal Error
1 REPLY 1
387 Views, 1 Reply
I have Map3D 2010 and Civil3D 2010 installed on the same box. I was using C3D to print maps that contained MrSID Images. This worked flawlessly for months - today it froze. I waited almost an hour and then shutdown the process manually and restarted. Now I can not use C3D or Map3D - I get this fatal error message: FATAL ERROR: Unhandled Delayload "acdb16.dll" Module Not Found Exception at 7c812afbh.
I have repaired and then reinstalled C3D - same error. I then uninstalled Map3D completely and reinstalled fresh with SP1 - same error.
I'm stumped - anybody have an idea what I can do to get this working.
Tom
1 REPLY 1
Sounds like a Windows update or another update ran. If the clean install of
Map3D didn't work then try a system restore back to few days ago.
Murph
http://map3d.wordpress.com/
wrote in message news:6311392@discussion.autodesk.com...
Tom
”Boost
