AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
map2sdf problem
1 REPLY 1
181 Views, 1 Reply
map2sdf problem
Hi all,
When I try to export a Mapguide SDF file using the "map2sdf" command in
Autocad 2000i, one of two things happen:
1) If I try to do a coordinate conversion, I get an 'Export Failed'
message
2) If I don't do a co-ord conversion, The .sdf file that is produced is
on visible anywhere on my mapguide map.
Is there a major roblem with AutoCad 2000i's 'map2sdf' utility that I
don't know about. Incidently, I'm using Mapguide Ver 4.
This problem has proved to be a 'showstopper'.Thanks in advance for any
info that might help me with this problem.
Michael Minick
Halifax, Canada
1 REPLY 1
In 2000i the conversion will fail if you convert an sdf containing a
coordinate system with a datum to a coordinate system with no datum (i.e.
CANQ27-M9 to generic Lat Long(LL)). Try converting to a coordinate system
that contains a datum.
Kevin
"Michael Minick" wrote in message
news:3BB8694D.14DAF195@gov.ns.ca...
> Hi all,
> message
> Michael Minick
> Halifax, Canada
”Boost
