With Mapplottransparency on the map is all turned to a raster image. What
you might try is plot without the text then plot again just the text and any
solid lines you want then merge the two pdf into one with Adobe.
If the text are labels from feature data you know that if you plot to dwf
with map objects the value of the field used to label from is searchable.
Murph
http://map3d.wordpress.com/
wrote in message
news:6351768@discussion.autodesk.com...
I would like to create a PDF or DWF from AutoCAD Map with
'mapplottransparency' set to On. It seems like all fonts are rasterized when
mapplottransparency is set On.
Is this really the case? Or is there a way to preserve the true type fonts
in the PDF or DWF?
