I use both Map and ArcGIS. Each is a valuable tool in our GIS toolbox. It is
like comparing two wrenches. Sometimes you need a combination wrench and
sometimes you need a socket wrench. They both do the samething but incertain
instances one might be better than the other for the task at hand.
Map has much easier to use drawing tools and is easy to integrate with our
engineer and surveyors using LDD and Civil 3D. The cleanup tools in Map are
nice as are the FDO connectors. Map also has some builtin 3D tools without
the need of extra extensions. If you have Civil 3D those are even better.
Maps biggest weakness are it's thematics and analysis tools when compare to
other GIS products such as ArcGIS.
ArcGIS has some definent advantages in a strictly GIS analysis area. In myy
opinion the queries, thematics and geoprocessing tools in ArcGIS are by and
far superior to Map's, though Map has been making steady improvements in
these areas. ArcGIS also handles large datasets much better than Map. ArcGIS
also had built in raster tools where Map requires Raster Design. I perfer
ArcGIS's version of topologies to Maps but these require at least ArcEditor.
ArcView will not allow users to create or edit topologies. Since Map is a
single level product it does not have this issue. ArcGIS's biggest weakness
is editing spatial data when compared to a CAD based program.
Both programs will work with multiple data formats either through importing
or a direct connection. Both programs can reproject data from one coordinate
system to another. Both programs can produce high quality prints.
Tripp Corbin, MCP, CFM, GISP
Vice President, GIS/IT
ESRI Authorized Instructor
Keck & Wood, Inc.
(678) 417-4013
(678) 417-8785 fax
www.keckwood.com
wrote in message news:6028571@discussion.autodesk.com...
Looking at the cost difference to use Map 3D or ESRI. We currently own 9
licenses of LD/Civil 3D which include Map. Part of our research has been
from two sources, an ESRI user and Autodesk sales rep. I hope to get
responses from individual who are familiar with Map, and hopefully Arcview.
The following are the justifications for the ESRI products from an ESRI
user, are they true?
Map 3D is very basic. It is essentially a viewing tool. There may be
additional products for AutoDesk which would provide advanced capability. It
is not set up to dovetail with RAS; there would be an intermediate step
required to produce maps from RAS data if an AutoDesk project is used.
All FEMA mapping contractors are using ESRI products as is the rest of the
world. It seems like ESRI is much like Microsoft in the early days.
The ESRI 3D Analyst Extension product would be useful once we start down the
path of manipulating DFIRM data or perhaps for projects where
cross-sectional information would be loaded directly into RAS with the
mapping being generated immediately from the RAS results.
The basic software, ARCVIEW, would allow drainage areas, land use and CNs
to be developed and calculated in hours instead of days with Map. With Map
there is no connectivity between quad sheets, soils maps, land use maps,
aerial photos, but with ARCVIEW there is.
The Map3D learning curve is inefficient, were as ESRI products is much
simpler.
Much of the GIS data which we could use with the ESRI products is FREE! All
that is needed is to download the information. Not so with Map
We did get feedback from our sales rep addressing the above comments as
follows:
Map will perform everything that Arcview and the ESRI 3D Analyst Extension
add on do with the exception of:
- Viewshed and line-of-sight analysis, spot height interpolation, profiling,
and steepest path determination, calculate surface area and volumes. Note
Civil 3D and Land Desktop (both have Map 3D inside of them) will calculate
- VRML support (web publishing via MGE)
- animation recording (additional product needed)
Map is capable of utilizing and exporting to ESRI information. "Supposedly"
there are no translation problems.
Map is capable of performing everything ESRI 3D Analyst Extension does, with
the exceptions listed above, so it should be able to manipulate DFIRM data.
The sectioning capability for Map is done via Land Desktop or Civil 3D.
Map can utilize the same information as Arcview. The calculations can be
done as efficiently as ESRI.
Training for Map is as simple as ESRI products and since you have
individuals that are experienced with Land Desktop/Civil 3D, I would assume
the training for Map 3D would be minimized.
The free stuff for ESRI products is available and usable in Map, see above
for compatibility.
In addition Map has some analysis capabilities via theming using Aspect and
Slope that Arcview and the 3D Analyst Extension do not.
Civil 3D/LD/Raster 2009 Update 1
Vista 64 bit
8 gb ram
X9000 @ 2.8 GHz, Core 2 Extreme SP1
