AutoCAD Map 3D General Discussion
*Josh
Message 1 of 3 (219 Views)
Map Import - Insufficient Memory Error
219 Views, 2 Replies
11-22-2002 02:38 AM
When I try to import a large shape file of contours
for a whole county I get an insufficient memory error. Then it boots me out of
AutoCAD. I have 1G of memory on my computer and I believe it should be able to
handle it. Does anyone got a suggestion??
*McIntyre, Mark
Message 2 of 3 (219 Views)
Re: Map Import - Insufficient Memory Error
11-22-2002 03:19 AM in reply to: *Josh
You may need to change the Virtual Memory setting on your computer. Use
your Windows help. You may also need to reset your swap file size.
Good luck!
Josh wrote:
 When I try
to import a large shape file of contours for a whole county I get an insufficient
memory error. Then it boots me out of AutoCAD. I have 1G of memory on my
computer and I believe it should be able to handle it. Does anyone got
a suggestion??
*Josh
Message 3 of 3 (219 Views)
Re:
11-25-2002 11:23 PM in reply to: *Josh
Thank You, it worked.
You
may need to change the Virtual Memory setting on your computer. Use your
Good luck!
Josh wrote:
 When I try to
insufficient memory error. Then it boots me out of AutoCAD. I have 1G of
memory on my computer and I believe it should be able to handle it. Does
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
