AutoCAD Map 3D General Discussion
Map Import - Insufficient Memory Error
220 Views, 2 Replies
11-22-2002 02:38 AM
When I try to import a large shape file of contours
for a whole county I get an insufficient memory error. Then it boots me out of
AutoCAD. I have 1G of memory on my computer and I believe it should be able to
handle it. Does anyone got a suggestion??
*McIntyre, Mark
Post 2 of 3
Re: Map Import - Insufficient Memory Error
11-22-2002 03:19 AM in reply to: *Josh
You may need to change the Virtual Memory setting on your computer. Use
your Windows help. You may also need to reset your swap file size.
Good luck!
Josh wrote:
 When I try
to import a large shape file of contours for a whole county I get an insufficient
memory error. Then it boots me out of AutoCAD. I have 1G of memory on my
computer and I believe it should be able to handle it. Does anyone got
a suggestion??
Re:
11-25-2002 11:23 PM in reply to: *Josh
Thank You, it worked.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
You
may need to change the Virtual Memory setting on your computer. Use your
Good luck!
Josh wrote:
 When I try to
insufficient memory error. Then it boots me out of AutoCAD. I have 1G of
memory on my computer and I believe it should be able to handle it. Does
