AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map Import - Insufficient Memory Error
2 REPLIES 2
402 Views, 2 Replies
When I try to import a large shape file of contours
for a whole county I get an insufficient memory error. Then it boots me out of
AutoCAD. I have 1G of memory on my computer and I believe it should be able to
handle it. Does anyone got a suggestion??
2 REPLIES 2
You may need to change the Virtual Memory setting on your computer. Use
your Windows help. You may also need to reset your swap file size.
Good luck!
Josh wrote:
 When I try
to import a large shape file of contours for a whole county I get an insufficient
memory error. Then it boots me out of AutoCAD. I have 1G of memory on my
computer and I believe it should be able to handle it. Does anyone got
a suggestion??
Thank You, it worked.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
You
may need to change the Virtual Memory setting on your computer. Use your
Good luck!
Josh wrote:
 When I try to
insufficient memory error. Then it boots me out of AutoCAD. I have 1G of
memory on my computer and I believe it should be able to handle it. Does
”Boost
