AutoCAD Map 3D General Discussion
Active Member
GIS_user
Message 1 of 9 (668 Views)
map image insert NAIP raster photo not reprojecting and 4 bands
668 Views, 8 Replies
07-20-2012 10:53 AM
Hello all,
I have limited experience with AutoCAD, I am an ESRI GIS user. So here goes:
We are trying to use map image insert to insert a NAIP photo. The NAIP photo is in UTM meters. The existing AutoCAD Civil dwg is in state plane illinois wf. Everything I have read says all you have to do is go to map image insert, pick the tiff, my correlation source is a world file (.tfw), and BAM, your raster image should show up where it is supposed to. Well, it doesn't work. Does anyone have any ideas? It appears that AutoCAD is not reprojecting the image to state plane feet. How can I get it to do this?
If we connect to the image, it reprojects it just fine. However, on every pan and zoom it is redrawing. We can't wait for the program to redraw all the time, it's too slow. So if we can figure out how to import it, it's a much faster option.
Another problem: the NAIP has 4 bands and the 4th band is an Alpha Band 1. This makes the image appear faded and white. In ArcMap you can simply uncheck the 4th band so the image looks normal again. Is there a way to do that in AutoCAD Map?
Thank you,
Andrea
The _MAPIINSERT command does not reproject anything on-the-fly.
You should import your UTM imagery in an empty drawing, assign a CRS with _ADESETCRDSYS, and save.
Then open your State Plane drawing, attach the UTM one with _ADEDRAWINGS, finally perform a draw query to embed it in the current SP map.
You can't: Autocad is able to handle the main transparency in the raster properties, but only with mono .TIF and color .PNG files, sir.
antoniovinci
Message 2 of 9 (655 Views)
Re: map image insert NAIP raster photo not reprojecting and 4 bands
07-22-2012 02:17 AM in reply to: GIS_user
Active Member
GIS_user
Message 3 of 9 (636 Views)
07-23-2012 11:14 AM in reply to: antoniovinci
Very helpful, Thank you!!
Distinguished Contributor
cjneper
Message 4 of 9 (622 Views)
07-24-2012 05:47 AM in reply to: GIS_user
There is a way to do this...
If you insert the image into a blank drawing that has the image's coordinate system assigned, then save that drawing containing just the image.
Then open the drawing with the coordinate system you want it projected to, query the image drawing into this drawing, and it will be projected to the new coordinate system.
antoniovinci
Message 5 of 9 (614 Views)
07-24-2012 06:45 AM in reply to: cjneper
Just explained two posts above (22-07-2012 12:17 PM): why repeating the same one, sir?
cjneper
Message 6 of 9 (612 Views)
07-24-2012 06:48 AM in reply to: antoniovinci
oops.  Did not see that one.  Sorry.  Good answer by the way :-)
Active Member
GIS_user
Message 7 of 9 (563 Views)
08-06-2012 01:13 PM in reply to: antoniovinci
I have a different drawing that is in WGS84 and I queried in my stateplane .sid from a stateplane dwg, just like the above workflow. I am using AutoCAD Map 2011 in this project. When I go to close it, AutoCAD map warns me that my queried objects will not be saved. Then it says it has detached my dwg and it asks if I want to detach the image. I click on No.
When I open it again the command line says "Activating drawing...done". But my image does not show up until I go to the Task Pane and right click on my "Current Query" and click on "Execute as Defined". Is this normal?
Thanks for your help,
antoniovinci
Message 8 of 9 (554 Views)
08-06-2012 11:23 PM in reply to: GIS_user
I guess it happens 'cause you did not perform a "true" draw query: try to set like this below
Active Member
GIS_user
Message 9 of 9 (544 Views)
08-07-2012 06:24 AM in reply to: antoniovinci
Ok thanks. I had been doing that. I tried 2x to reproduce the same messages so I could screen shot them to you, and I can't get AutoCAD map to give me those messages again! So I will just say it was either user error or some sort of small bug that isn't reproducable. In any case, it's working great now. :smileyhappy: Thanks!
