AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
.map file import
1 REPLY 1
1588 Views, 1 Reply
.map file import
I admit to knowing almost nothing about microstation, but I have a
drawing file from microstation Geographics with a .map file extension
that I would like to import into map. Any ideas on how I can import
this? Or open it? Is this the actual drawing file?
Steve Engman
DCL Siemens Engineering Ltd.
1 REPLY 1
M82626
Steve, if you Microstation you should be able to open it. Also if it is a Microstation drawing you should be able to change the “.map” to “.dgn” which Map can import
If this dose not work E-mail me at jess.barringer@ibhc.com
Jess Barringer
”Boost
