AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map Export Error
1 REPLY 1
csoffice
560 Views, 1 Reply
Map Export Error
Using Map 5 I have a problem with Map Export. Error reads as follows:
Module AcMapImpExpUI.arx cannot load module AcMapImpExp.arx. The module may be missing, or another component upon which it depends may not be configured correctly.
I have looked in the Program folder and can see three files, the two listed above and a DLL file named AcMapImpExpUIResource. This is a new error as I have used this routine numerous times without problem. Is there another file referenced that may have been corrupted?
Thanks for any answers
Neil
1 REPLY 1
in reply to: csoffice
try this solution from Autodesk
http://usa.autodesk.com/adsk/servlet/ps/item?id=2889972&linkID=2786831&siteID=123112
wrote in message news:4821463@discussion.autodesk.com...
> Neil
”Boost
