AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map coordinates change when dwg is queried
2 REPLIES 2
411 Views, 2 Replies
I open a new drawing and assign it Lat Long NAD 83 coordinates. The Tracking Coordinates box and the box in the bottom left hand side of the status bar all track the same Lat Long Coordinates.
I then attach a drawing that is in State Plan coordinates and Query the entire drawing.
Here is where the problem occurs. Once I zoom extends to see the entire map the Tracking Coordinates box no longer tracks anything and the box in the status bar show it tracking the original State Planes coordinates from the queried drawing.
I thought that querying a drawing into another would make it use the coordinates assigned to the working drawing.
Am I wrong in thinking this?
2 REPLIES 2
When you attached your drawing (state planes) before you run the query go to coordinate system again and under source drawing click select drawing and select your state plane and give it the state plane cord system. Then run your query.
jessebelcher-tvec
That helps alot. Thanks!!!!
”Boost
