AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map 3d multileaders disappear
1 REPLY 1
srfnhooker
269 Views, 1 Reply
I am using map 3d 2011 and i am running into issues with the use of multi-leaders.  I have a dwg with a few shape files in it and I have added multileaders to the dwg.  When I save, close and then reopen the file the multileaders show up for a brief second during the loading process but then they disappear.  All my settings are correct (layers, visibility, scales) as far as the leaders go but I can't figure out what the heck is going on.  I tried adding another, select similar and only the one shows up that I just added.  Saved the file and reopened. Same thing, the leader I just added shows up with the others for a brief second and then "poof" gone!!!  Anybody out there have any idea whats going on?
1 REPLY 1
have you check "Base map" in the workspace palette?
Olivier
”Boost
