AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map 3D Legend inside block causes - FATAL ERROR
2 REPLIES 2
ceethreedee.com
520 Views, 2 Replies
I have been adding my "unlinked" MAP 3d Legends to blocks lately so i can share it across my drawings.
When I remove the associated layer from map pane. then pan over to where the legend is displayed. Boom - FATAL ERROR town!
FATAL ERROR; Unhandled Access Violation Reading 0x01b4 Exception at dc3ff404h
See below.
Legend in Block
Remove Layer
BOOM TOWN^^
Kapanther
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
2 REPLIES 2
dcrnila
in reply to: ceethreedee.com
Map Legend is very unstable.
Here is a similar example:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Unhandled-access-violation-reading-0x01b4-Exception-a...
Do you have problem like this too?
Tags (1)
Well I haven't got a raster connection added so no. Also my legend will only crash when I remove the layer the legend was using. Because the legend is in a block reference it crashes.
Infraworks 2021.1,
ceethreedee.com
”Boost
