AutoCAD Map 3D General Discussion
Active Member
tsimenc
Message 1 of 3 (765 Views)
Map 3D 2013 ECW
765 Views, 2 Replies
07-12-2012 05:08 AM
ECW file 6.5 GB big is not connecting via FDO in Map 2013. Error states: "Failed to open FDO connection." and "File does not exist."
That particular file CAN be opened in Map 2012, and it CAN be inserted into Map 2013 via Raster Desgn...
Did anybody noticed such a behaviour ?
yooper_75
Message 2 of 3 (738 Views)
Re: Map 3D 2013 ECW
07-13-2012 05:53 AM in reply to: tsimenc
I have experienced the same issue. After working with support, the final answer was "Yes, that does not work correctly. Try to use 'mapiinsert'." If you find a way to make it work, please let me know...
Carl
M3D 2012 and 2013
Win 7 Pro x64
HP 8200 i7 - 16GB RAM
AMD Radeon HD 6350
Active Member
tsimenc
Message 3 of 3 (736 Views)
Re: Map 3D 2013 ECW
07-13-2012 06:32 AM in reply to: yooper_75
I'll try to figure it out... I need to use ecw rasters via FDO, mapiisnert is not usable in my case... -- Srda?an pozdrav / Kind regards Tomislav ?imenc Direktor EDC d.o.o. Antuna ?trbana 18 10000 Zagreb tel. +385 1 6539717 fax. +385 1 6539716 gsm. +385 98 576526 mailto: tomislav.simenc@edc.hr url: www.edc.hr
