AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map 3D 2013 ECW
2 REPLIES 2
tsimenc
1048 Views, 2 Replies
Map 3D 2013 ECW
ECW file 6.5 GB big is not connecting via FDO in Map 2013. Error states: "Failed to open FDO connection." and "File does not exist."
That particular file CAN be opened in Map 2012, and it CAN be inserted into Map 2013 via Raster Desgn...
Did anybody noticed such a behaviour ?
2 REPLIES 2
in reply to: tsimenc
I have experienced the same issue. After working with support, the final answer was "Yes, that does not work correctly. Try to use 'mapiinsert'." If you find a way to make it work, please let me know...
Carl
tsimenc
I'll try to figure it out... I need to use ecw rasters via FDO, mapiisnert is not usable in my case... -- Srda?an pozdrav / Kind regards Tomislav ?imenc Direktor EDC d.o.o. Antuna ?trbana 18 10000 Zagreb tel. +385 1 6539717 fax. +385 1 6539716 gsm. +385 98 576526 mailto: tomislav.simenc@edc.hr url: www.edc.hr
”Boost
