AutoCAD Map 3D General Discussion
Member
c.schmidt
Message 1 of 3 (166 Views)
Map 3D 2012 Window looses focus when using Acad-functions
166 Views, 2 Replies
07-10-2012 02:00 AM
hello community!
i have a problem.
When i use standard Acad-functions or even simply
select an object like a polyline from land-survey,
the "ribbon" changes to the corresponding Topic of the object,
and the Map3D window looses its focus. (normal windows-mouse-cursor is displayed,
not the AutoCAD crosshair). After clicking in Map 3D window again, crosshair reappears,
and work can continue.
It doesn't matter if Map3d-windows is in windowed mode or fullscreen,
it also doesn't matter if the windows is only on one of my 2 monitors or on both.
didn't have this problems using Topobase Client 2009,2010,2011...
but since 2012 few problems evolved... (drawing-order-bug, memory-leak problem etc. etc.)
quality of the software product Topobase or "Map 3D" is getting worse and worse....
Alfred.NESWADBA
Message 2 of 3 (147 Views)
Re: Map 3D 2012 Window looses focus when using Acad-functions
07-10-2012 12:26 PM in reply to: c.schmidt
do you have installed the latest service-packs?
have you opened the property-window? ...and if so does the problem also occure if you have the poperty-window closed or minimized or undocked?
- alfred -
Alfred NESWADBA
Member
c.schmidt
Message 3 of 3 (139 Views)
07-11-2012 02:16 AM in reply to: Alfred.NESWADBA
Alfred, you're my man.
After closing the properties window (which was fixed displayed under the legend on the right)
the issue is gone.
THX so much man!
