AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map 3D 2012 Window looses focus when using Acad-functions
2 REPLIES 2
c.schmidt
383 Views, 2 Replies
hello community!
i have a problem.
When i use standard Acad-functions or even simply
select an object like a polyline from land-survey,
the "ribbon" changes to the corresponding Topic of the object,
and the Map3D window looses its focus. (normal windows-mouse-cursor is displayed,
not the AutoCAD crosshair). After clicking in Map 3D window again, crosshair reappears,
and work can continue.
It doesn't matter if Map3d-windows is in windowed mode or fullscreen,
it also doesn't matter if the windows is only on one of my 2 monitors or on both.
didn't have this problems using Topobase Client 2009,2010,2011...
but since 2012 few problems evolved... (drawing-order-bug, memory-leak problem etc. etc.)
quality of the software product Topobase or "Map 3D" is getting worse and worse....
2 REPLIES 2
Alfred.NESWADBA
in reply to: c.schmidt
do you have installed the latest service-packs?
have you opened the property-window? ...and if so does the problem also occure if you have the poperty-window closed or minimized or undocked?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
c.schmidt
in reply to: Alfred.NESWADBA
Alfred, you're my man.
After closing the properties window (which was fixed displayed under the legend on the right)
the issue is gone.
THX so much man!
”Boost
