AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map 3D 2011 Status bar
7 REPLIES 7
Message 1 of 8
sandene84
459 Views, 7 Replies
I have recently reinstalled Autocad, and have some problems with the status bar. It seems that the button to switch between 2d/3d, vertical exaggeration, view scale etc. have disappeared from the status bar. See attachment. How can I bring these back?
7 REPLIES 7
Message 2 of 8
antoniovinci
in reply to: sandene84
Try to issue the _MAPSTATUSBAR command...
Message 3 of 8
sandene84
in reply to: antoniovinci
Allready tried that one. Mapstatusbar is an unknown command. Maybe that's were the problem is?
Message 4 of 8
antoniovinci
Are you really sure you wrote the underscore sign BEFORE the command?
Must be _MAPSTATUSBAR, sir.
Message 5 of 8
sandene84
Tried both 😉
Message 6 of 8
antoniovinci
According to this:
http://docs.autodesk.com/MAP/2010/ENU/AutoCAD%20Map%203D%202010%20User%20Documentation/HTML%20Help/i...
it should work, unless the command was dismissed in 2011 release.
If that's the case, my apologies...
Message 7 of 8
braudpat
Hello from France
Just an idea, this trick could be the solution (not tested on 2011) ...
Please play with REGEDIT ...
HKEY_CURRENT_USER
-- Software
---- Autodesk
------ AutoCAD
-------- R17.0
---------- ACAD-500x:40C
------------ Applications
-------------- AcMap
Create Key (DWORD) "Statusbar"
If value = 0 then Status Bar  "AutoCAD Classic"
If value = 1 then Status Bar  "MAP 3D 2007"
HKEY_CURRENT_USER / Software / Autodesk / AutoCAD / R1x.x
Key : R17.0 for MAP/CIVIL 2007
Key : R17.1 for MAP/CIVIL 2008
Key : R17.2 for MAP/CIVIL 2009
Key : R18.0 for MAP/CIVIL 2010
Key : R18.1 for MAP/CIVIL 2011
Please let us know ...
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 8 of 8
sandene84
in reply to: braudpat
I did some more searching, and it seems the problem was deeper than first assumed. All special Map features were not functional, and the "Map" drawdown menu (in classic workspace) had disappeared. When I reloaded the CUI, the functions were still not working. I went to control panel and did a full installation repair, and that solved the problem.
”Boost
