AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map 3d 2011 raster image regen freeze
2 REPLIES 2
freerefill
340 Views, 2 Replies
I'm having an issue where the more I zoom into a drawing that has a raster image (a 1mb jpg) in it, regenerating times become increasingly long until the whole program just freezes. When I zoom back out, it's fine.
I've tried changing the file type, saving it with a different program, lowering the quality to Draft, zooming in on an area that the raster image wasn't in, lowering the DPI of the image, nothing works. I've spent the last two hours searching Google for a fix, found nothing. The only thing that seems to work is if I put the image on a layer and freeze it. The problem there is, I'm tracing over the image, so it being invisible makes it rather difficult to work with.
I do a lot of work with jpgs, and this issue is going to make my life hell. Can anyone help?
2 REPLIES 2
antoniovinci
in reply to: freerefill
Try to save that .JPG in an empty .DWG, then load it as XREF: how does it behave?
freerefill
in reply to: antoniovinci
Behaves the same. No change.
”Boost
