HI
I want to connect to Mysql database but MAP 3D 2011 refusing to do it. I'll tried both Mysql Community Server 5.5 and 5.0.27 versions but nothing. I installed server to localhost and used service name for MAP connections: localhost, 127.0.0.1 with port name without but I cant get connected.
I didn found any useful help to fix that problem, Mysql service is running and tested it seems that problem must be in MAP side.
Does anybody know which version is working with MAP 2011 and
Kajar
It's been a while since I connected to a MySQL database (2008 version) and I used just localhost as the service name. Version 5.0.27 is the version that works with MAP3D according to the help files. Have you copied the libmySQL.dll file into the AutoCAD Map 3D\FDO\bin folder?
