Yup, and it isn't pretty, at least not from my experience. I get a list of errors - Most of which I can't recall right now so I won't type one out and send someone on a wild-goose chase.
I tried it on a xp64 system, with a clean install of Civil3D. None of the Map or Civil commands work, only the standard vanilla CAD ones.
I don't have time to dedicate to getting it to work, but if someone manages to get it going, I'd love to hear how they did it. I had it working once by dragging some ARX files that it said it couldn't find into the drawing window. If I did it in the right order, at the certain time of day, when the wind was blowing from the east, it would work.
I suspect it's just a matter of pathing Acad to find the right files, but damned if I have time for it. I tried the fix on the adesk site for the similar error I was experiencing, but had no luck.
Andrew
Reply Syntax?
Command (Uppercase): TRIM, Variable (Italicized): MSLTSCALE, Civil 3D Object (Within brackets): [SITE]
If this solves your issue or answers your question then please hit the KUDO button or mark as an ACCEPTED SOLUTION!
Please support my Idea to revert the forum format to the old one: https://forums.autodesk.com/t5/community-ideas/revert-to-old-forum-layout/idi-p/7917987
