AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
MAP 201X 64 bits and ArcSDE v9.3 SP1 32 bits ?
4 REPLIES 4
braudpat
575 Views, 4 Replies
Hello
I have already seen MAP 2010/2011/2012/2013 32 bits connected to ESRI ArcSDE v9.3 32 bits
with the famous 3 DLLs (sde, sg, pe) added into bin/fdo (or fdo/bin) using ArcSDE FDO driver ...
I hope it is working ALSO with MAP 2014 32 bits !?
But how is it possible to connect a MAP 2010/2011/2012/2013/2014 version 64 bits
to the same ESRI ArcSDE v9.3 SP1 32 bits ?
I haven't the 3 DLLs in 64 bits versions
If the customer switch to ArcSDE 64 bits, which DLLs (into bin/fdo or fdo/bin),
I need to connect with the 64 bits ArcSDE FDO driver ?
Where can I find these DLLs ??
And which minimum version of ArcSDE 64 bits, I need ???
After searching ... In the MAP 2013 ReadMe, I can find this :
--- FDO ArcGIS Provider ---
The ArcGIS Provider is limited to 32 bit only. There is no 64 bit support for ESRI’s ArcGIS databases.
So I am very afraid : it seems to be impossible !
======> And with MAP 2014 64 bits, is it the same limitation ???
--- Requirements for MAP 201X 32/64 bits ---
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15421202&linkID=9240857
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
4 REPLIES 4
braudpat
in reply to: braudpat
Hello
When looking at this Info :
http://docs.autodesk.com/MAP/2014/ENU/system_requirements/map3d-sys-reqs.htm#OSWin64
It seems that the FDO Esri ArcSDE driver 64 bits (of MAP 2014 64 bits)
is able to connect with a 32/64 bits ESRI ArcSDE v9.3/v10 !?
If somebody has the Info, please let me know ...
If somebody knows the exact names of the DLLs, we need in 64 bits version , let me know ...
Thks, Bye, Pat
Patrice BRAUD
Cadguru42
@braudpat wrote:
Hello
Thks, Bye, Pat
The filenames are the same, but they are for the 64-bit ArcSDE. You'll have to get them from ESRI. I downloaded the 64-bit service pack for ArcSDE and it includes the 3 files that need to be placed into the FDO folder.
C3D 2022-2024
Windows 10 Pro
32GB RAM
braudpat
in reply to: Cadguru42
Hello
Thks for the Info, I will give you feedback asap ...
GeoBye, Pat
Patrice BRAUD
Checkout my blog post on how to find and extract the ESRI sde dlls
http://totalcad.wordpress.com/2011/10/24/finding-and-extracting-the-64-bit-sde-dlls/
”Boost
