AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map 2015
10 REPLIES 10
Message 1 of 11
cjneper
2245 Views, 10 Replies
Map 2015
Is there any inside knowledge on the release of Map 2015... namely will this be a 64 bit only release?
Also, I assume 2015 will not work on XP?
10 REPLIES 10
Message 2 of 11
Murph_Map
in reply to: cjneper
Those that know can't say and those that say don't really know.
Murph
Supporting the troops daily.
Message 3 of 11
cjneper
in reply to: Murph_Map
"Can't say"?? You're not giving away company secrets here.
I'd like to know what platforms my soon to arrive Autodesk Map upgrade will run on so I make sure I order appropriate machines to run the product.
At this point in the development process I'm pretty sure this has been determined already.
Message 4 of 11
DarrenP
autodesk stopped supporting XP with some of the 2014 products
with 2015 XP will not be supported with any product
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Microso...
DarrenP
Message 5 of 11
braudpat
Hello
Autodesk has officially announced (Microsoft ALSO for April 2014 : no update, no patch, no support, etc) the "END" (of Support) for Win XP ...
So it's not top-secret that the 2015 versions will not support Win XP Pro ...
Please remind that Win XP Pro began in about 2001, it is/was the longest supported OS from Microsoft !
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 6 of 11
cjneper
Thanks.  I did hear about the end of XP support.
I know the Civil product went to 64 bit only last year, so I am wondering if Map will be 64 bit only this year, or if a 32 bit version will still be available.
Message 7 of 11
braudpat
Hello
1) Please remind that Autodesk has stopped with 2014 the 32 bits versions of : CIVIL, 3DS Max, AIW (Ex AIM)
2) My opinion / wish for 2015 versions : please stop 32 bits software with MAP, Architectural, MEP, etc
and keep 32 bits versions ONLY for ACAD and ACAD LT ...
3) BUT the customers are the Kings and so many people are always running Win Seven 32 bits ...
4) MAP 2014 32 bits has a special FDO driver : ARCGis
which is not present (if I remember well) with the 64 bits version of MAP 2014 ...
So I bet for a 32 bits version of MAP 2015 but not sure at all !?
Patrice BRAUD
Message 8 of 11
DarrenP
in reply to: braudpat
if this is the case Autodesk will probably still make a 32 bit version of Map 3d
i guess we will wait & see when they release it
DarrenP
Message 9 of 11
diane.cloutier
Thank you for your inquiry.  AutoCAD Map 3D 2015 will be released in both 32-bit and 64-bit.  And you are correct that Windows XP will not be supported for the 2015 release.  Thanks,
Diane Cloutier
Message 10 of 11
cjneper
in reply to: diane.cloutier
Thank you Diane!
Message 11 of 11
braudpat
Hello
Sorry I can't answer "exactly/immediately" to your question because NDA !
But now you have the correct answer from Autodesk....
Patrice BRAUD
”Boost
