Just installed 2014 and already a problem...
I am trying to import a SHP file that I have successfully imported in previous versions. It works to connect to it via FDO but I need to create some object data, so need to use Mapimport. I am getting the error: IMPORT SHAPEFILE ERROR: FDO PROVIDER 'OSGEO.SHP.3.7' NOT REGISTERED.
Ideas?
Solved by braudpat. Go to Solution.
Hello
Please look at this Topic, it could be the solution :
http://forums.autodesk.com/t5/AutoCAD-Map-3D/export-to-shp-file-in-2014/m-p/3914293#M39433
Bye, Pat
Patrice BRAUD
