AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map 2014 Import Shp error
2 REPLIES 2
cjneper
1375 Views, 2 Replies
Just installed 2014 and already a problem...
I am trying to import a SHP file that I have successfully imported in previous versions.  It works to connect to it via FDO but I need to create some object data, so need to use Mapimport.  I am getting the error: IMPORT SHAPEFILE ERROR: FDO PROVIDER 'OSGEO.SHP.3.7' NOT REGISTERED.
  Ideas?
2 REPLIES 2
braudpat
in reply to: cjneper
Hello
Please look at this Topic, it could be the solution :
http://forums.autodesk.com/t5/AutoCAD-Map-3D/export-to-shp-file-in-2014/m-p/3914293#M39433
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
cjneper
in reply to: braudpat
Replacing the "Providers.xml" file solved the problem.  Thank you.
”Boost
