Is it possible to install the 32-bit version of Map 2012 on the 64-bit version of Windows 7? We are using custom programs that only work in 32-bit.
Solved by Alfred.NESWADBA. Go to Solution.
sorry the simple answer is NO.
- alfred -
Hi grimline,
>> YES [...]
And then you can start the pc with Win7x64 and run Map3Dx32?
I can imagine how the installation of Map3D under WinXPx32 will run, that's ok. But if you start then Win7x64 I can not imagine how Map3D would be runable as there are no registry-entries, not the correct paths, ...?
Could you describe how the installation should be done that this could work?
- alfred -
>> Yes you can, in this environment
OK, yes ... VirtualXXX can run Map3Dx32 when the (Guest)OS for this VirtualXXX is a 32bit-OS. And once more yes, ... it's a great peace of software and I often need VMWare to do some testing for development (as it's easy to siimulate a lot of different environments without needing to setup a pc).
But for 10hours work a day I never would use any VirtualXXX as everything emulated is slower than the original, especially for AutoCAD the graphicsperformance is not the same as running on a performance-gc in the main-pc.
My question was (and I think also the question of the TO) Is there a way to run Map3Dx32 on an oSx64 (and that answer imho is NO).
Anyway thank you for thinking on VirtualXXX as that may help some people 😉
- alfred -
Guys, trust me, the virtual solution is not viable for CAD work. I'm using 32bit AutoCAD on 64bit Windows day in day out, works fine. You do have to use a little utility to get it working though, and it costs a few bucks, but honestly it saved me a lot of headache and everything just works as before. It's called the Longbow Converter, search for it online.
Yes, it's an option, but: are you sure that is legal?
If I read the license-agreement for AutoCAD (or any legacy rules for software, whatever source) no one is allowed to modify files from the vendor. What Longbow Converter does (as far as I understand it): it modifies the installation-script (that may be the allowed task), and it exchanges files (from 64bit to 32bit) ==> that is imho the critical part now.
If you have asked Autodesk if you are allowed to modify these files, then everything is ok (and let us know that also) 😉
Not that I say "it's forbidden", but I would first ask before doing that!
- alfred -
