Having difficulties making successful connection...any help would be appreciated:
Running Map 2011 (64-bit) and trying to connect to ArcSDE 9.3\SQL 2008 R2 (32-bit).
Have copied the 64-bit files (sde.dll, sg.dll, and pe.dll) to AutoCAD FDO/bin folder.
Have added esri_sde_ss 5151/tcp to C:\windows\system32\drivers\etc\services file.
When trying to connect get the following error:
"Failed to connect.
FDO Provider entry point function 'CreateConnection' returned NULL"
Have successfully connected to server using ArcGIS.
How did you get the 64-bit files if you're using the 32-bit SDE? You might need to try the 32-bit drivers and see if that works.
Maybe this would help.
