AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map 2010 Export ??
16 REPLIES 16
Message 1 of 17
cloquet
793 Views, 16 Replies
Map 2010 Export ??
I recently upgraded to 2010. When i try to Export my .shp files i always get "0 object(s) of 1141 selected, exported in 0 sec(s)."
I use the map, tools, export command and use my same .epf files that i created for all of my .shp files from 2008.
I've even tryed making completely new .epf files to download and it still gives me the 0 objects exported on the command line.
But if i save the .dwg back and open it in 2008, the export works fine??
Any ideas why it will not export in 2010??
Thanks.
16 REPLIES 16
Message 2 of 17
in reply to: cloquet
What types of objects are you exporting? SHP files can only store one geometry type (point/line/polygon) per file.
Are you trying to export polygons from polylines? There's an option to specify that closed polylines are treated as polygons.
- Jackie
Message 3 of 17
cloquet
I have point objects & polyline objects and none of them will export.
i get the same "0 files export" message in the command line for everything
Message 4 of 17
Did you ever get this resolved, Cloquet?
I am having the same issue - the same error message and I've tried exporting lines, polylines, etc. I've tried checking the box "treat closed polylines as polygons". I tried converting my coordinate system on the final tab. I tried all forms of object selection.
I'm still getting that error message. Mine is this: "0 object(s) of 1313 selected. Exported in 0 sec(s)."
Any ideas?
Thanks for any help from anyone. This topic hasn't received enough attention - first posted in 2006!
Anna
Message 5 of 17
antoniovinci
Start over with a new empty file, draw ONE line and export it to shape: have you the same issue?
Message 6 of 17
parkr4st
in reply to: antoniovinci
op stated was exporting a .shp file, not to a .shp file.  which is it?
dave
Message 7 of 17
Is there a database link involved in the export, check that it is recognizing the link if you are exportiing data with the file.
John
Message 8 of 17
antoniovinci
It doesn't matter, sir.
Even if the database link is dead, Autocad will be able to export the geometry to a shapefile, without those Object Datas.
Message 9 of 17
@ antoniovinci,
I tried your suggestion. I drew a line in a new document and gave it an elevation as if I were drawing contours. I tried to export using the command "mapexport" and I got the same error message.
Interestingly, yesterday evening I found a post that suggested the command "mapexport4". I tried that and I was able to export a shapefile however, I couldn't figure out how to include Elevation information in the export. The dialog box for "mapexport4" is completely different than the dialog box for "mapexport".
With regard to the other suggestion, I am not using any database with this file at this time.
Any info on the specifics of these two export methods?
Anna
Message 10 of 17
Murph_Map
@Anonymous wrote:
@ antoniovinci,
Anna
What version are you using and is it just AutoCAD Map3D or Civil 3D? You posted back in May in the 2008 version forums are you still on 2008 or have you upgraded?
Murph
Supporting the troops daily.
Message 11 of 17
in reply to: Murph_Map
I am using AutoCAD Civil 3D with Map 3D. I guess the Map 3D was something we paid for additionally. I'm not exactly sure how that works, but I know that's what we have.
I tend to ask questions within posts on the same topic started by someone else. In May of 2008, I was not using 2008 software, that's just the forum where I found related info.
Thanks for your time, Murph. Does my response ring any bells?!
Anna
Message 12 of 17
Murph_Map
The Civil3D is built on top of Map3D therefore you have all of Map3D when you have Civil3D. t's best if you post in the forum for the software and version that you are using, alot of the helpers in here may not look or follow the older forums and the issues may have different fixes.
Now to your issue, if you are using 2010 version do you have all of the service pack/updates installed?
Murph
Message 13 of 17
Murph,
We check for updates at least once a month it seems, so I expect it's currently up-to-date.
Would you recommend I start my own post on this topic in the Civil 3D forum?
Message 14 of 17
I am using autocad map 2012 as of now but seem to recall an issue with the external files being moved during upgrades. I would also look into the issue of shp field headings.  Map 2012 automatically truncates to ten but in the past having illegal field headings  was a problem during export. There are many variables to what could be causig the problem but it seems to be centered around the upgrade.
John
Message 15 of 17
NateMoore
Could it be this?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13251791&linkID=9240697
If that section of the interface is missing, nothing will be exported (though the .shp file will be created).
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
Message 16 of 17
in reply to: NateMoore
WOW....It worked!
I'm blown away.
Now I understand why Murph wanted me to post in the forum for the software version I'm using.
Thanks everyone!
Anna
Tags (1)
Message 17 of 17
Murph_Map
@Anonymous wrote:
WOW....It worked!
I'm blown away.
Thanks everyone!
Anna
The version and vertical you use does help finding fixes along with your system spec.
Murph
”Boost
