AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Manually redrawing 19th century raster maps
9 REPLIES 9
Message 1 of 10
Piet22
406 Views, 9 Replies
I am new to Map 3D. I have to redraw 19th century raster maps that cannot be vectorized automatically.
The borders of the parcels are heavily curved.
I insert the raster map and start to trace/draw on a new layer.
1. Now, if I want to draw a second parcel that has a common curvy border with a first parcel how do I best trace the common border? What I would like is that the vertices along the common border are all displayed so I could just click them rapidly to draw the common border of the second parcel. However I cannot find a way to display all vertices. Is there a solution for this?
2. For drawing a new parcel alongside multiple existing parcels, a beter/faster option would be that I just click the vertices on junctions of the common border and the software would automatically trace the line between the junctions, create all vertices and snap them to the existing vertices on the common border of the existing parcel. Is there a solution for this?
Piet
9 REPLIES 9
Message 2 of 10
antoniovinci
in reply to: Piet22
You don't need to draw the common border, since Autocad Map does it automatically.
When you end the raw vectorization:
  1. first perform a _MAPCLEAN procedure, with "Break crossing objects" and "Dissolve pseudo nodes" actions
  2. then _MAPTOPOCREATE a polygon topology
  3. finally _MAPCLPLINE to generate closed polylines for every parcel
Message 3 of 10
Piet22
in reply to: antoniovinci
Many thanks, this could be a perfect solution!
Some new questions now if I may?
1.
"breaking crossing objects" breaks the common border away from parcel 1 and makes it a separate polyline.
"mapclpline" closes the parcels 1 and 2 along this separated polyline.
The separated polyline is not removed after that, so the common border has now 3 lines on top of each other.
Is this OK? Should I remove this separated polyline afterwards?
2.
Sometimes after reviewing the results some adjustments must be made to the position of some vertices.
If I click a vertex on the common border of parcel 1 and move it, the underlying vertex of parcel 2 does not move with it. All my Osnap options are on. How can I set Autocad to make all snapped vertices move together?
3.
What exactly is the difference between a node and a vertex? If I click a vertex/node and move it, Autocad calls it a vertex but "maptocreate" calls the same item a node?
Thanks again
Piet
Message 4 of 10
antoniovinci
in reply to: Piet22
Answer #1
The command _MAPCLPLINE allows you to create the closed polys on a new layer, so you can easily freeze the layer containing the manually drawn border.
Answer #2
Use the _STRETCH command instead.
Answer #3
I think "node" means "centroid", but let's wait for an Autodesk specialist opinion...
Message 5 of 10
parkr4st
in reply to: Piet22
Peit
vertex
A location where edges or polyline segments meet.
node
A type of object snap that locates point objects, dimension definition points, and text origin points.
topology
A set of geometric relationships between drawing objects, including links, nodes, and centroids. Topology describes how lines, nodes, and polygons connect and relate to each other, and forms the basis for advanced GIS functions such as network tracing, spatial analysis, buffer analysis, overlay analysis, and dissolving a polygon topology.
In AD help, Contents tab learnAutoCAD Map 3D list is glossary.  You can check there for the definiton of terms
you can move multiple stacked vertex by selecting with a window over the vertex point. then all will move together
another option for what your doing is to have two dwg layers, draft and polygons.  draft on the draft layer , switch to the polygon layer and use Bpoly command to draw the polygons.  -boundary is now the command.  Bpoly still works from the command line and a search in help for Boundary will explain the process.
dave
Message 6 of 10
Piet22
Answer #1: OK
Answer # 2: I think I use "stretch". If I click the vertex, the command line shows "stretch" and the little menu near the arrow shows the options stretch vertex/ remove vertex/ add vertex. However, when I drag the vertex the underlying vertices do not move with the upper vertex. If I type "stretch" in the command line Autocad wants me to select objects; however I do not want to move objects, only vertices.
Answer #3: OK
Many thanks again!
Piet
Message 7 of 10
Piet22
in reply to: Piet22
Thanks Dave, will experiment.
Piet
Message 8 of 10
antoniovinci
in reply to: Piet22
The _STRETCH command requires a selection from right to left onto the stacked vertexes...
Message 9 of 10
Piet22
Hello Antoniovinci and Dave,
Your methods both work well so my original problem is now almost solved.
Almost because I am not completely happy with the fact that each method leaves an unclosed polyline behind.
The solution of adding the results of the operation to a new layer works fine if you do the operation only once but I work on maps with more than 1000 parcels so I tend to work step by step. Every 50 parcels or so i would like to perform the operation and then the results of the previous steps are also left behind on the layer with the unclosed polylines. Is there a method to delete all unclosed polygons? I think this would make me completely happy.
Piet
Message 10 of 10
antoniovinci
in reply to: Piet22
As said before, you should create the topology AFTER the complete manual vectorization.
Once the polygon topology is correctly generated, you get INSTANTLY all the closed polylines thru _MAPCLPLINE.
In other words: the tedious work is to draw the old scanned paper, while the clever finishing belongs to the powerful tools of Autocad Map.
”Boost
