AutoCAD Map 3D General Discussion
Member
zcrispin0.autodesk
Message 1 of 3 (130 Views)
Make thematic map of external data linked to labels
130 Views, 2 Replies
11-30-2012 07:39 AM
Ok, so in map3d I can use
attach data source
connect data source
define link templates
generate data links
(in that order) to attach data in an excel spreadsheet to a bunch of text objects in my drawing.  The spreadsheet is keyed on the text in the text objects.
However - I can't then make a thematic map based on this data!  Using the thematic map tool, with either "data" or "sql" expression, acad reports that "No link templates exist".  Which seems odd because I already linked the data in using one.
Can anyone solve this problem for me?
antoniovinci
Message 2 of 3 (119 Views)
Re: Make thematic map of external data linked to labels
11-30-2012 11:18 AM in reply to: zcrispin0.autodesk
Which ODBC driver did you use to link your DWG objects to the Excel records?
Member
zcrispin0.autodesk
Message 3 of 3 (102 Views)
12-03-2012 06:16 AM in reply to: zcrispin0.autodesk
Microsoft OLE DB Provider for ODBC Drivers (well this is what it says in properties for the attached data source anyway)
