hi
i have Autocad map 3d 2012 install on my working computer (network licence/subscription) and when i try opening project in maintenance workspace i always get this message/error (when i click on open project button).
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.TypeInitializationException: The type initializer for 'Topobase.Map.Loader.TopobaseLoader' threw an exception. ---> System.BadImageFormatException: Could not load file or assembly 'Topobase.GwsInterface, Version=9.0.118.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. An attempt was made to load a program with an incorrect format.
at Topobase.Map.Loader.Initialization.b..ctor()
at Topobase.Map.Loader.Initialization.b.a()
--- End of inner exception stack trace ---
at Topobase.Map.Loader.TopobaseLoader.MapDbConnect()
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.296 (RTMGDR.030319-2900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
AdApplicationFrame
Assembly Version: 0.0.0.0
Win32 Version: 3.2.23.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AdApplicationFrame.DLL
Acdbmgd
Assembly Version: 18.2.0.0
Win32 Version: 18.2.51.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcdbMgd.DLL
System
Win32 Version: 4.0.30319.1001 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
msvcm90
Assembly Version: 9.0.30729.4940
Win32 Version: 9.00.30729.4940
CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4940_none_08e4299fa83d7e3c/msvcm90.dll
AdWindows
Assembly Version: 3.2.23.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AdWindows.DLL
PresentationFramework
Win32 Version: 4.0.30319.298
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
i have try to uninstall/reinstall Autocad map 3D 2012, copy *.cui files from another computer with same Autocad install and cleared all my entries in registry
My computer is part of a office network and is the only computer getting this error message
i have also tried doing what is mention in this links without any result
http://www.cadtutor.net/forum/archive/index.php/t-49705.html
it looks like it has something to do with topobase loader
does anybody recognize this error and have answears?
thanks
I would start with verifying the installation of Framework 4 and then the installation of Map3D.
First step is to check if Framework 4.5 is installed, if so (and you are not running Win8) then you might start with uninstalling it.
Next step is to repair the Framework 4.0 installation (control panel ==> software ==> select the Framwork 4 to get the button "Repair install" enabled ==> click it.
If that (including a reboot in the meantime) does not help then do a repair-install of Map3D (same steps in control panel ==> software).
Good luck, - alfred -
