I am losing the coordinate system when opening a saved drawing. The original drawing had coordinates from generate graphics using a tbdm in maintenance workspace. Any ideas will be helpful.
Hi Deeter,
I haven't heard of opening a drawing and then noticing that its originally assigned coordinate system assignment disappeared! So I cannot think of a reason how this would happen. (Unless -- did another user open it and run the GEOREMOVE command and then save the drawing?) Also I cannot find any past cases on this kind of issue when searching internally...
In any case, your model should not be affected. Simply run the MAPCSASSIGN command and, if need be, assign your coordinate system again.
Phil
