AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Lost coordinate system
1 REPLY 1
deetersmith
334 Views, 1 Reply
I am losing the coordinate system when opening a saved drawing.  The original drawing had coordinates from generate graphics using a tbdm in maintenance workspace. Any ideas will be helpful.
1 REPLY 1
phil_borycens
in reply to: deetersmith
Hi Deeter,
I haven't heard of opening a drawing and then noticing that its originally assigned coordinate system assignment disappeared! So I cannot think of a reason how this would happen. (Unless -- did another user open it and run the GEOREMOVE command and then save the drawing?) Also I cannot find any past cases on this kind of issue when searching internally...
In any case, your model should not be affected. Simply run the MAPCSASSIGN command and, if need be, assign your coordinate system again.
Phil
Phil Borycens
”Boost
