AutoCAD Map 3D General Discussion
Active Contributor
Jfactory
Message 1 of 2 (205 Views)
Lose labels when rotating view
205 Views, 1 Replies
02-27-2014 04:01 PM
Hi I've had this problem for a while and never found a solution or took the time to ask for help.
I am using AutoCAD Map 3D 2013 SP 2.1 64 Bit Windows 7.
When I am in Layout space if I have a rotated view that is not World View my labels for SDF and SHP files disappear.  Is there any solution to this?
I have tried 2 methods of rotating the view, one is UCS customizing with a PLAN view oriented to the current UCS. Labels disappear.
The other method is DVIEW and TWisting all my features N degrees. Labels disappear.
I usually end up making labels for the few things I need labeled but this time it covers a large area.
Any help would be much appreciated, thank you!!
Hi, This is a known issue (up to the current version) with line features and has been logged with our developement team to be fixed for future releases.  Are you having this issue for line features only or is it also an issue for points and polygons?  It hopefully should not be a problem with points and polygons, but let me know if it is.  As a workaround, you can convert the labels to MText using the MAPLABEL2ANN command.  Sorry I do not have any other solution for you at this time.
Product Support
diane.cloutier
Message 2 of 2 (167 Views)
Re: Lose labels when rotating view
03-05-2014 07:49 AM in reply to: Jfactory
Diane Cloutier
