AutoCAD Map 3D General Discussion
Active Member
bakerjd21
Message 1 of 2 (108 Views)
lookup lists in Map 6?
108 Views, 1 Replies
11-20-2002 12:29 AM
I plan on using Map 6 to convert utility data into a dwg. I have an Access database attached as a data source and have created a link templates. How do I create lookup lists (pick lists) that limit the values that can be entered? I have tried creating the lookup lists in Access, but Map doesn't seem to utilize them. I have also entered a range of values in the feature class area. Unfortunately, it limits the values but doesn't provide a picklist. Also, the values don't seem to be limited when using the Data View interface to change attributes.
Any help would be appreciated. I've spent many hours on this, but feel like I hit a brick wall!!!
Jason
*Friedrich, Scott
Message 2 of 2 (108 Views)
Re: lookup lists in Map 6?
11-20-2002 02:05 AM in reply to: bakerjd21
"bakerjd21" wrote in message
news:f125697.-1@WebX.maYIadrTaRb...
Jason
Unfortunately, Map Dataview does not support Look Up Tables - this has been
a wish list item for a while now. The only alternative is to create your
own Dataview through customization.
Scott
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
