AutoCAD Map 3D General Discussion
Active Member
HAL0
Message 1 of 10 (382 Views)
Local license vs network license
382 Views, 9 Replies
01-23-2013 05:59 AM
We want to check and be sure that our licenses are correct for our company.
We have discovered that some of our HKLM\Software\Autodesk\Serialnumber is marked as 000-00000000 which might be considered as trial? At the same time, if we go to Help > About it shows the correct serial as shared from our FlexLM licenses.The key StandaloneNetworkType is set to 3 which should be Network License mode. Also, sometimes is StandaloneNetworkType set to '0'. So I am not sure what is safe here.
Can anybody inform us about how we ensure that our setup is legal?
DarrenP
Message 2 of 10 (373 Views)
Re: Local license vs network license
01-23-2013 06:04 AM in reply to: HAL0
only way to check is to verify your serial numbers with your reseller
thats the easiest
Active Member
HAL0
Message 3 of 10 (371 Views)
01-23-2013 06:11 AM in reply to: DarrenP
well checking our install and distribution method might be a long process so I hoped for some help here.
DarrenP
Message 4 of 10 (365 Views)
01-23-2013 06:16 AM in reply to: HAL0
what exactly are you trying to determine?
seat count?
serial number?
products & versions?
Active Member
HAL0
Message 5 of 10 (363 Views)
01-23-2013 06:18 AM in reply to: DarrenP
im trying to ask if its legal to have a local registry 000-00000000 as long as help > about shows the correct serial and you are licensed.
DarrenP
Message 6 of 10 (360 Views)
01-23-2013 06:21 AM in reply to: HAL0
as along as the product has the correct serial number you should be fine
Active Member
HAL0
Message 7 of 10 (358 Views)
01-23-2013 06:23 AM in reply to: DarrenP
thanks. do you know if its legal to use older serials locally? we have older products like 2011-products (we are allowed to use 2010-2013 products in our license). can we use serials from 2011 locally or do we have to replace them?
DarrenP
Message 8 of 10 (353 Views)
01-23-2013 06:25 AM in reply to: HAL0
you use the 2011 serial number
as along as you aren't exceding the number of license as you own
Active Member
HAL0
Message 9 of 10 (344 Views)
01-23-2013 07:03 AM in reply to: DarrenP
thanks. well reading about this seems not so easy as you type here... when companies like http://www.scottandscottllp.com/main/Preventative_Step_to_Reduce_Exposure.aspx seem to specialize in this
have you ever been involved in a autodesk license revision of a company?
DarrenP
Message 10 of 10 (336 Views)
01-23-2013 09:00 AM in reply to: HAL0
no i have not
