AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Loading Shp file Issues
2 REPLIES 2
460 Views, 2 Replies
Im trying to load .shp files made from ArcMap 10.1 and continually get an error labeled “Invalid Repository Type”. I can’t seem to find any information on what exactly a repository type is or how to correct it. Someone please help! Thanks Scott
2 REPLIES 2
antoniovinci
Erase all but SHP/DBF/SHX/PRJ files and try again: seems like something's wrong with the shape index.
If it doesn't work, zip and attach here the 4 above mentioned files, thanx.
Thanks that worked!
”Boost
