AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Lisp for replacing block with point?
4 REPLIES 4
3180 Views, 4 Replies
Dear madams and sirs,
I need to replace a large number (3700) of blocks with points, and cannot find a command for that operation. I have found a lisp for converting circles to points, so I guess it is doable for someone more experienced.
Have I just not found the command, or am I a bad googler? Unfortenately I cannot handle pure code (yet), so I need a lisp file (or the command).
Thankful for any help!
/ Göran
4 REPLIES 4
Murph_Map
You can always do a report query or a dataextract and create a txt file with the coordinates of the blocks then use that txt file to import points. Another way would be to export the points to SHP format then import them as points. To erase the current blocks use the Quick select command.
Murph
Supporting the troops daily.
antoniovinci
I think it's feasible in Gis opensource environment: feel free to attach here that .DWG in 2004 format, I could try.
in reply to: Murph_Map
Thanks!
I tried the method of exporting/importing via shape file, and it worked out well.
Off to new adventures!
/ Göran
Murph_Map
@Anonymous wrote:
Thanks!
/ Göran
Great, glad to help out.
Murph
”Boost
