AutoCAD Map 3D General Discussion
Active Contributor
torentrue
Message 1 of 8 (532 Views)
Link Template does not appear
532 Views, 7 Replies
09-25-2012 09:06 AM
I have a client with AutoCAD Map 3D 2011 with an OLE DB Provider for SQL Server Data Source and a dbConnect link template connecting to the database.
Normally, when an object that is linked to the database via the link template is selected, the data from the linked table appears in the properties palette. Recently a change what made to the table (view) that the link template and the Link template no longer appears. The view was restored to its original state, but the link table still is not visible.
If the data source is disconnected via the task pane, the link template reappears (with only the key showing, of course). The data can still be seen via the link template "View Linked Table" context-sensitive menu in the task pane so the link still remains.
I have disconnected, deleted, and rebuilt the data source, but it has not helped and I cannot delete the link template as there are several thousand objects linked via the template.
Any help is appreciated.
antoniovinci
Message 2 of 8 (522 Views)
Re: Link Template does not appear
09-25-2012 11:16 AM in reply to: torentrue
In your shoes, I wouldn't try to repair anything, sir.
Rebuilding the links of some thousand objects is a matter of minutes, so my advice is: start over with a clean _ADEGENLINK
Active Contributor
torentrue
Message 3 of 8 (507 Views)
09-26-2012 11:49 AM in reply to: antoniovinci
Antonio,
Thanks for the quick reply. Can you point me to some documentation that can help me rebuild this Link Template?
antoniovinci
Message 4 of 8 (499 Views)
09-26-2012 11:12 PM in reply to: torentrue
http://docs.autodesk.com/MAP/2012/ENU/filesMWG/GUID-C6EA7620-0D64-441D-8897-DF848B6A7598.htm
Active Contributor
torentrue
Message 5 of 8 (486 Views)
09-27-2012 09:26 AM in reply to: antoniovinci
Thanks again. Before I try this, I want to make sure we are talking about the same thing. I have several drawings (10-15) with identical link templates. The drawings display the same behavior (If the data Source is connected, the LT_XXX information does not appear. If the Data source is NOT connected, the LT_XXXX apears with only the Key [as would be expected]) Nothing has been changed in the other drawings and they have only been opened to verify the occurance of the trouble. Thanks,
antoniovinci
Message 6 of 8 (482 Views)
09-27-2012 11:46 AM in reply to: torentrue
As already said, I would forget the old link template, starting over with a brand new one: make a _WBLOCK of the only geometry, ensure that every closed object has an unique ID drawn inside, and connect them to the database.
Active Contributor
torentrue
Message 7 of 8 (460 Views)
09-28-2012 03:09 PM in reply to: torentrue
As much as it pains me to report this, the whole problem was that the key in the database table (view) had been removed so the Link template had nothing to "Key" on. All is now right in the world.
Thanks for your help!
antoniovinci
Message 8 of 8 (450 Views)
09-28-2012 11:28 PM in reply to: torentrue
Without IDs drawn, there's only one way to link to the DB records, i.e. by means of the Object Data: what you see if you check the properties of a closed poly?
