AutoCAD Map 3D General Discussion
Active Member
davidsona
Message 1 of 1 (36 Views)
linework offsets when printing
36 Views, 0 Replies
04-25-2008 07:24 AM
I'm using Map 3D 2009 to start. I've imported a JPG as part of of a map base as I've done thousands of times in the past. I've then traced a series of lines from that inserted JPG for the purposes of brining attention to it.
When I go to print on either 11x17 (to an HP colour LaserJet 5550dn) or plot (to an HP DesignJet 1050c plus) the image is fine but the new linework created is shifted drastically down about 3 mm (1/32"). I've even printed it out to PDF file format with the same results.
Please note: I've recently added a hotfix (dll file swap - adimaging_hotfix_32bit) and this problem started after that. Unfortunately I need that dll in place or Fatal Errors occur 15-30 times a day.
