I've tried to simulate that linetype before, but to the best of my knowledge, a single linetype that would create what you're after isn't possible in AutoCAD. In MAP2005, you could use a display style to get something close to it. A typical linetype definition is a series numbers representing pen-up/pen-down, not offsets, etc. One other possible route that I looked into, but found to be too much trouble, was mlines. Good luck to you, but I don't expect you'll find a convenient answer.
Reply Syntax?
Command (Uppercase): TRIM, Variable (Italicized): MSLTSCALE, Civil 3D Object (Within brackets): [SITE]
If this solves your issue or answers your question then please hit the KUDO button or mark as an ACCEPTED SOLUTION!
Please support my Idea to revert the forum format to the old one: https://forums.autodesk.com/t5/community-ideas/revert-to-old-forum-layout/idi-p/7917987
