AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Lines won't appear on top of an Xref
1 REPLY 1
Acemon
1539 Views, 1 Reply
I have a drawing with one viewport. In model space I have attached a jpg. If I draw a line over the xref in model space, it looks fine. When I switch to paper space, the line does not show, but if I plot to a pdf, it does. If I draw on paperspace, above the viewport, the line does not show.
The jpg is black lines on a white background. If I draw a line across it in model space, it shows up as the correct color (in this case it's red) but when I switch to paperspace it turns white and is invisible over the image.
I tried to change the display order, but no win. I checked the properties of the line and the xref itself and it all looks good. Everything is set "by layer".
Naturally, I'm frustrated. So is my boss.
1 REPLY 1
karsten.loewen
in reply to: Acemon
Hey Acemon,
Initially I thought it might be related to a viewport override setting, but the fact that it plots to PDF fine throws that idea out the window 😛
If you haven't already, I would suggest:
  - Remove all VP Override settings
  - Running AUDIT in your drawing
  - Try it with differenti mage type (.png, .gif, .bmp etc...)
  - Run through the same steps inew drawing (maybe even from different template)
Let me know if that helps or not! 😄
Karsten
”Boost
