AutoCAD Map 3D General Discussion
Distinguished Contributor
bingeomatics
Message 1 of 16 (444 Views)
Line style
444 Views, 15 Replies
08-25-2012 12:12 AM
Hello!
Who can help me? I want to creat a line style for feature objects (line object) wich symbols only on the vertex of the line. How can I do it?
Binnat Khalilov
set style like this if i understand what you want
Valued Mentor
parkr4st
Message 2 of 16 (438 Views)
Re: Line style
08-25-2012 04:46 AM in reply to: bingeomatics
one way shown in the attachments.  is this for display only or some other reason?
Valued Mentor
parkr4st
Message 3 of 16 (435 Views)
Re: Line style
08-25-2012 04:52 AM in reply to: parkr4st
How I did the display manager. two uses of same shp file #3.  and with the line work layer off #4.
You could also get the nodes at the ends of lines as points and style the points in a seperate layer.
dave
bingeomatics
Message 4 of 16 (408 Views)
Re: Line style
08-26-2012 04:02 AM in reply to: parkr4st
Thank you, parkr4st, for to try help me!
But I don't want to creat seperate layers. I want to do it only on liner layer. An example, I want to creat a power trust which was shown  on the picter.  I can to make a liner layer which symbols (blocks). But in AutoCAD Layer Style Manager we can do it by giving interval between symbols. If I want to give a symbol only for the vertex of the line, it is impossible. Have any way to creat style like that?
Power trust
Binnat Khalilov
Valued Mentor
parkr4st
Message 5 of 16 (405 Views)
Re: Line style
08-26-2012 04:44 AM in reply to: bingeomatics
bingeomatics
Message 6 of 16 (376 Views)
Re: Line style
08-26-2012 09:48 PM in reply to: parkr4st
No, this method, which you show, inserts the symbol only to the start and end vertexes. But I need to insert it to all vertex
Binnat Khalilov
Valued Mentor
parkr4st
Message 7 of 16 (366 Views)
Re: Line style
08-27-2012 12:59 AM in reply to: bingeomatics
mapimport, explode the poly lines to lines, new sdf or shp and apply the style.
dave
antoniovinci
Message 8 of 16 (360 Views)
Re: Line style
08-27-2012 01:48 AM in reply to: bingeomatics
Without creating any new linetypes, here's  a free tool doing what you wish, sir.
bingeomatics
Message 9 of 16 (356 Views)
Re: Line style
08-27-2012 02:25 AM in reply to: parkr4st
But I thing that is not normally cartographic method. Because, every power trust must be one whole polygonal object and one raw in database table. Thank you very much, parkr4st, for trying to help me. I understand that in AutoCAD Map have not cartographic (styling) function like that......:smileyembarrassed:
Binnat Khalilov
Valued Mentor
parkr4st
Message 10 of 16 (347 Views)
Re: Line style
08-27-2012 03:46 AM in reply to: bingeomatics
Binnat
what is a power trust so I will know in the future?  i haven't heard the term.
dave
