I've been working in a file for a while and jut started having this issue today. When I first open the drawing, all lines are in their correct color, but as soon as the layer manager loads up, the lines all change to a light grey color. When I select a line, the properties box shows the line in its correct color. Also, if I select the line and edit it, ( extend, shorten, displace, etc...) it changes back to the correct color. Has anyone else had this issue or anyone have an idea of how to rectify it? I've already tried to shut down MAP and restart it.
Jordon
Solved by rkmcswain. Go to Solution.
