There must be a way to limit the length of a value used in an annotation template. I am labeling from an attached database and one of the attributes I am using is sometimes too long for the maps so I need to limit the number of characters used. Is there a way to limit character length when using a value attached from a database?
Thank you,
Kraig
Solved by jagielski. Go to Solution.
Upload an example of the dwg and what field and the number of charathers you want. There may be a way.
something like that
(substr XXXXX 1 (min 132 (strlen XXXXX)))
where XXXXX is the field you want to display and 132 (for ex) the max number of character you want.
Olivier
Olivier,
I modified the link and tried again. It doesn't like the min statement. For the (strlen XXXXXX) should the XXXXXX be my link template value, or the value of the max characters desired?
I am using this statement -
(substr &GRANTEE@link 1 (min 32 (strlen &GRANTEE@link)))
When I use this statement I get a warning mesage that says "Unsupported operator specified in expression: min"
Kraig
Thank you for the help. I was able to work through this with a little guidance. This is what I came up with that works for me -
(substr &GRANTEE@link 1, 35)
1 being the min and 35 being the max for what I want.
