Question :
Can I transfer my license back and forth from my laptop (32bit) and my work station (64bit) using the license transfer utility?
Solved by TravisNave. Go to Solution.
Solved by thepworth. Go to Solution.
yes
- alfred -
Better question - Are you on Subscription?
If so, you can have 1 license for your "Work" workstation and request "home use" for your laptop....
Look in your subscription center / talk to your reseller for details.
Cheers!
True. You should just activate both as the EULA allows for exactly what you are asking. Forget the LTU as it is problematic.
